Understanding Lineage Tree on versioned DB
986
09-03-2013 03:51 AM
PeterSchilling
Hi fellow Esri ArcSDE - Folks.
I am running a ArcSDE 10.0 on Oracle 11.2.0.3 DB. I try to understand how the Lineage Tree is built during the Edit-Session.
The following steps are done:
1. Open Edit-Session.
2. Select a line.
3. Open Attribute Table
4. Switch one attribute from 0 to 1
5. Save Edit-Session
6. Close Edit-Session.
I repeated the this procedure and observed the Lineage-Tree with GDBT in ArcCatalog.
I would expect a long linear Lineage-Tree, but it was otherwise. (See PDF).
--> My Question is, what for are these open Lineages, which go to a Dead-End next to the "Main-Tree"?
Greets and thanks,
Peter
JakeSkinner
Esri Esteemed Contributor
Hi Peter,
Take a look at the following KB article on how the state tree changes:
http://support.esri.com/en/knowledgebase/techarticles/detail/32352
