SDE Geodatabase Error
2054
09-04-2013 08:03 AM
slindelokhanyile
I'm trying to import feature class into SDE geodatabase but these errors keep showing. Please see the attached files for your attention.
by Anonymous User
Not applicable
Original User: JSkinn3
This is most likely caused because one (or many) of the feature classes within the feature dataset is published as service.  Stop the service, and then you should be able to export the feature class to the SDE feature dataset.
by Anonymous User
Not applicable
