Unable to run Diagrammer
3748
11-13-2012 10:01 AM
MuryadiOey
I installed Diagrammer 10 and my win7 computer that has desktop 10, .Net framework 4 client profile and 4 extended. I have looked around but didn't get any clue why Diagrammer couldn't run and threw error Unhandled Exception Error. according to a thread, it was mention about ESRI .Net assemby, I checked that as well.
Can anyone help me?
Thank you[ATTACH=CONFIG]19260[/ATTACH]
dkav
I am having the same problem. I have ArcGIS 10.1 installed on my Windows 7 64-bit PC.
Here is the full error -
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.TypeInitializationException: The type initializer for 'ESRI.ArcGIS.Diagrammer.DiagrammerEnvironment' threw an exception. ---> System.IO.FileNotFoundException: Could not load file or assembly 'ESRI.ArcGIS.System, Version=10.0.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86' or one of its dependencies. The system cannot find the file specified.
File name: 'ESRI.ArcGIS.System, Version=10.0.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86'
   at ESRI.ArcGIS.Diagrammer.DiagrammerEnvironment..ctor()
   at ESRI.ArcGIS.Diagrammer.DiagrammerEnvironment..cctor()
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
   --- End of inner exception stack trace ---
   at ESRI.ArcGIS.Diagrammer.DiagrammerEnvironment.get_Default()
   at ESRI.ArcGIS.ArcDiagrammer.FormDiagrammer.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.5466 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    Assembly Version: 10.0.1.0
    Win32 Version: 10.0.1
    CodeBase: file:///C:/Program%20Files%20(x86)/ArcGIS%20Diagrammer/BIN/ESRI.ArcGIS.ArcDiagrammer.exe
    Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
SandBar
    Assembly Version: 1.4.2.1
    Win32 Version: 1.4.2.1
    CodeBase: file:///C:/Program%20Files%20(x86)/ArcGIS%20Diagrammer/BIN/SandBar.DLL
ESRI.ArcGIS.ExceptionHandler
    CodeBase: file:///C:/Program%20Files%20(x86)/ArcGIS%20Diagrammer/BIN/ESRI.ArcGIS.ExceptionHandler.DLL
    CodeBase: file:///C:/Program%20Files%20(x86)/ArcGIS%20Diagrammer/BIN/ESRI.ArcGIS.Diagrammer.DLL
SandDock
    Assembly Version: 3.0.5.1
    Win32 Version: 3.0.5.1
    CodeBase: file:///C:/Program%20Files%20(x86)/ArcGIS%20Diagrammer/BIN/SandDock.DLL
Crainiate.ERM4
    Assembly Version: 4.1.2966.41885
    Win32 Version: 4.1.2966.41885
    CodeBase: file:///C:/Program%20Files%20(x86)/ArcGIS%20Diagrammer/BIN/Crainiate.ERM4.DLL
Accessibility
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Xml
    Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Security
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Security/2.0.0.0__b03f5f7f11d50a3a/System.Security.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
dkav
Applying the latest Windows updates after installing Diagrammer resolved the problem.
