Unable to Publish Service with ArcSDE Data
1269
02-08-2011 01:49 PM
parikshitranade
I am new to ArcSDE. I installed ArcSDE and successfully created the SDE geodatabase with DBO schema. But I am unable to create feature or geodata service. I tried to create MXD, MSD services through ArcMap publisher, ArcCatalog and ArcGIS server manager (.NET). It gives following error.
Configuration firesdetest.MapServer can not be started.
Server Object instance creation failed on machine parikshitgisser.
  Bad login user
  The Layer:'firetest' in Map:'Layers' is invalid.
Bad login user
Any suggestions would help.
Parikshit
ChristineZeller
pkranade,
Did you solve this problem.  I'm running into the same issue.
Christine
ModyBuchbinder
Hi Christine
You should remember that the publisher is the ArcSOC owner (usually ArcSOC account).
If the MXD that you publish contain OS authentication you must make sure this user can connect to ArcSDE.
If you use database authentication you must make sure the password is saved in the MXD.
Have Fun
Mody
