unable to open RPC connection to external procedure agent
7016
6
03-30-2015 06:48 AM
Nurullah_Beşli
Hi I know that there is a lot of discussion about this error. But when i tried to apply the sollution presented, i still get the same error.
Here is my problem definition.
I have
-2.6.18-371.6.1.el5 GNU/Linux 64 bit
-Oracle 11.2.0
-Arcgis 10.2
installed.
I create a geodatabase using arccatolog software, and after that i import some tables to this geodatabase. However when i try to use some functions of this geodatabase such as st_astext i get "unable to open RPC connection to external procedure agent" error. The complete error list is given below.
ORA-28575: unable to open RPC connection to external procedure agent
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 67
ORA-06512: at "SDE.ST_GEOMETRY_OPERATORS", line 118
28575. 00000 -  "unable to open RPC connection to external procedure agent"
I checked for this error and found out that oracle requires some configurations for calling functions from extarnal libraries.In this case the library is libst_shapelib.so. I tried to make some configrurations in accordance to oracle documantation. The content of listener.ora, tnsnames.ora and extrproc.ora is given below.
listener.ora
ID_LIST_LISTENER =
  (SID_LIST =
    (SID_DESC =
      (SID_NAME = PLSExtProc)
      (ORACLE_HOME = /u01/app/oracle11/product/11.2.0/dbhome_1)
      (PROGRAM = extproc)
    (SID_DESC =
      (GLOBAL_DBNAME = PGEO01)
      (SID_NAME = PGEO01)
    (SID_DESC =
      (SID_NAME = PLSExtProcSDE)
      (PROGRAM = extproc)
        (ENVS="EXTPROC_DLLS=/geocode/arcgis/server/lib/libst_shapelib.so")
    (SID_DESC =
      (SID_NAME = xxxxxx)
      (PROGRAM = dg4odbc)
      (ENVS="LD_LIBRARY_PATH=/u01/app/oracle11/product/11.2.0/dbhome_1/bin")
LISTENER =
  (DESCRIPTION =
    (ADDRESS = (PROTOCOL = TCP)(HOST = xxx.xx.xxx.xx)(PORT = 1525))
    (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROCSDE1528))
#----ADDED BY TNSLSNR 19-FEB-2014 16:45:13---
PASSWORDS_LISTENER = xxxxxxxxxxx
tnsnames.ora
PGEO01=
   (DESCRIPTION=
      (ADDRESS=
         (PROTOCOL=TCP)
         (HOST=xxx.xx.xxx.xxx)
         (PORT=1525)
      (CONNECT_DATA=
         (SERVER = DEDICATED)
         (SERVICE_NAME=PGEO01)
EXTPROC_CONNECTION_DATA =
  (DESCRIPTION =
    (ADDRESS_LIST =
      (ADDRESS = (PROTOCOL = IPC)(Key = EXTPROCSDE1528))
    (CONNECT_DATA =
      (SID =PLSExtProcSDE)
      (PRESENTATION = RO)
PGSQL  =
  (DESCRIPTION=
    (ADDRESS=(PROTOCOL=tcp)(HOST=xxx.xx.xxx.xxx)(PORT=1525))
    (CONNECT_DATA = (SID = xxxxx))
    (HS = OK)
extproc.ora
-I tried all options below:
SET EXTPROC_DLLS=
SET EXTPROC_DLLS=ANY
SET EXTPROC_DLLS=ONLY:/dddd/arcgis/server/DatabaseSupport/Oracle/Linux64/lib
After changing this files. I got the same error. As error indicates that there are 3 possibilities for this error.
- Something wrong in tnsnames or listener. ora files
-Incorrect keys or not matching
-Network issues
-Or the library is corrupted.
I still think that i dis some mistake in the tnsnames and listener . ora file configuration. But i do not know where is the mistake can you help me .
one final note:
my lsnrctl status output is:
Listening Endpoints Summary...
  (DESCRIPTION=(ADDRESS=(PROTOCOL=ipc)(KEY=LISTENER)))
  (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=xxx.xx.xx.xxx)(PORT=1525)))
Services Summary...
Service "+ASM" has 1 instance(s).
  Instance "+ASM", status READY, has 1 handler(s) for this service...
Service "PGEO01" has 1 instance(s).
  Instance "PGEO01", status READY, has 1 handler(s) for this service...
Service "PGEO01XDB" has 1 instance(s).
The command completed successfully
Thank You for your Time
George_Thompson
Esri Notable Contributor
I would not recommend modifying the listener.ora file for the configuration of the ST_Functions with Oracle 11.2.
Please review the following documentation for setting this up within your Oracle geodatabase.
Configuring the Oracle extproc to access the geodatabase with SQL  - Look at the section for Oracle 11g only!!!
Be sure to update the EXTPROC.ora to ANY or the location of the .so file. Include the .so file name in the path.
Let us know the results.
--- George T.
Nurullah_Beşli
Hi
I made the changes described in the link that you gave. I basically add line
  -SET EXTPROC_DLLS=ONLY:/mypath/libst_shapelib.so
But the error remained same. When i tried to call st_function like st_asText or any other i got this error. I checked the file location.
   Error:ORA-28575: unable to open RPC connection to external procedure agent
Do you have any idea why i am getting this error. Here is my lsrnctl status result:
STATUS of the LISTENER
Alias                     LISTENER
Version                   TNSLSNR for Linux: Version 11.2.0.2.0 - Production
Start Date                30-MAR-2015 19:47:42
Uptime                    0 days 15 hr. 32 min. 42 sec
Trace Level               off
Security                  ON: Password or Local OS Authentication
SNMP                      OFF
Listener Parameter File   /mypath/listener.ora
Listener Log File         /mypath/alert/log.xml
  (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=xxx.xx.xxx.xxx)(PORT=1525)))
  (DESCRIPTION=(ADDRESS=(PROTOCOL=ipc)(KEY=extproc)))
Services Summary...
Service "PGEO01" has 2 instance(s).
  Instance "PGEO01", status UNKNOWN, has 1 handler(s) for this service...
Service "PLSExtProc" has 1 instance(s).
  Instance "PLSExtProc", status UNKNOWN, has 1 handler(s) for this service...
Thanks.
George_Thompson
Did you remove the reference from the listener.ora file (see underlined info below)? The issue seems to be a mix up of the configuration settings.
-Does the oracle account have access to the location of the .so file and permissions to execute against it?
SID_LIST_LISTENER =
  (SID_LIST =
    (SID_DESC =
      (PROGRAM = extproc)
    (SID_DESC =
      (SID_NAME = PGEO01)
    (SID_DESC =
      (PROGRAM = extproc)
    (SID_DESC =
      (SID_NAME = xxxxxx)
      (PROGRAM = dg4odbc)
Here is what my listener looks like. I know that is on Windows, but should be very similar.
SID_LIST_LISTENER =
  (SID_LIST =
    (SID_DESC =
      (SID_NAME = CLRExtProc)
      (ORACLE_HOME = C:\app\[install location]\product\11.2.0\dbhome_1)
      (PROGRAM = extproc)
      (ENVS = "EXTPROC_DLLS=ONLY:C:\app\[install location]\product\11.2.0\dbhome_1\bin\oraclr11.dll")
LISTENER =
  (DESCRIPTION_LIST =
    (DESCRIPTION =
      (ADDRESS = (PROTOCOL = TCP)(HOST = [machine name].esri.com)(PORT = 1521))
      (ADDRESS = (PROTOCOL = NMP)(SERVER = [machine name])(PIPE = ORAPIPE))
      (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1521))
ADR_BASE_LISTENER = C:\app\[install location]
Hope this helps!!
-George
--- George T.
Nurullah_Beşli
I am confused, you have reference to library in your listener file. Is it because you have different oracle version or shall i do the same. ?
Thanks
George_Thompson
I understand what you are saying, I think that this is specific to an Oracle library and not another product library.
If you are still having issues, you may need to contact Oracle support to have them help configure your EXTPROC to be configured properly.
Do you have another Oracle instance that you can test a clean workflow on?
-George
--- George T.
Nurullah_Beşli
Actually it is the only library that i need to use. And lsnrctl  restart takes a lot of time because of some required procedures. I will remove the file reference from listener.ora. the file path will be in only extproc.ora file as in the esri documantation. Than i will try it i let you know about results. Before listener restart
my listener file
LISTENER=
   (DESCRIPTION=
     (ADDRESS_LIST=
     (ADDRESS = (PROTOCOL = TCP)(HOST = xxx.xxx.xxx.xxx)(PORT = 1525))
     (ADDRESS=(PROTOCOL=IPC)(KEY=EXTPROC732))))
# line added by Agent
SID_LIST_LISTENER =
  (SID_LIST =
    (SID_DESC =
      (ORACLE_HOME = /mypath/dbhome_1)
      (SID_NAME = PGEO01)
PASSWORDS_LISTENER = 580EB7AB802BE1AA
LISTENER_+ASM=
  (DESCRIPTION_LIST =
    (DESCRIPTION =
      (ADDRESS = (PROTOCOL = TCP)(HOST = geopdb2)(PORT = 1525))
      (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1525))
ADR_BASE_LISTENER = /u01/app/grid
ENABLE_GLOBAL_DYNAMIC_ENDPOINT_LISTENER=ON              # line added by Agent
SECURE_REGISTER_LISTENER = (TCP)
and my tnsnames.ora file as below:
LISTENER_+ASM =
  (ADDRESS = (PROTOCOL = TCP)(HOST = xxxx)(PORT = 1525))
PGEO01=
   (DESCRIPTION=
      (ADDRESS=
         (PROTOCOL=TCP)
         (HOST=xxx.xxx.xxx.xxx)
         (PORT=1525)
      (CONNECT_DATA=
  (DESCRIPTION =
    (ADDRESS_LIST =
      (ADDRESS = (PROTOCOL = IPC)(Key = EXTPROC732))
    (CONNECT_DATA =
      (SID =PLSExtProc)
      (PRESENTATION = RO)
and i add following line to extproc.ora file.
do you see any thing wrong ?
Thank you for your help.
