Unable to create locator
2185
11-12-2010 08:32 AM
JasonHorning
I'm unable to create an address locator for a road centerline feature class within a feature dataset, which is also within a file geodatabase.  However, I AM able to create the locator if I pull my feature class out of the feature dataset.
JoeBorgione
I've never tried to build a locator within a feature dataset, but yep, you're right.  It can't be done.
That should just about do it....
JasonHorning
And, to be clear, I'm not trying to create the locator inside a feature dataset.  I'm just trying to create a locator for a geocoding source, which IS within a feature dataset.  Can't be done according to my version of ArcEditor 10.
JoeBorgione
Must be a new feature of 10.x.  I can do it at 9.3...
BradNiemand
There is no limitation for building locators with feature classes that reside within a feature dataset.  Can you post your data and I can take a look?
Brad
