unable to connect
3605
08-06-2015 11:32 PM
jayasudha
Hi, I am not able to connect for sde.
However, I am able to connect from oracle sqlplus client command line and also from arcgis desktop 10.1.
Also tested that tnsping works fine.
please suggest...
C:\>sdedbtune -o list -i sde:oracle11g:pmms -k DEFAULTS -u sde -p sde
ArcSDE 10.1  for Oracle11g Build 679 Thu Apr  5 11:43:21  2012
Attribute        Administration Utility
Error: Underlying DBMS error (-51).
Error: Could not create a connection on server JUPIT, for user sde.
Extended DBMS error code: 12154
ORA-12154: TNS:could not resolve the connect identifier specified
No extended error.
AsrujitSengupta
Do you have the Oracle 64-Bit Client installed and being used on the machine where you are executing the sde 10.1 commands.
jayasudha
Yes, both 64-bit and 32-bit clients are installed.
There are 5 more geodatabases on oracle and i am able to work with sde commands from same machine.
I am able to connect from arcgis desktop 10.1 and sql client.
But when i use sde command, i get TNS error.
jayasudha
I am able work with sde commands on the already existing geodatabases.
This problem is on new geodatabase created.
