Unable register database with arc gis server
6078
20
12-23-2013 08:28 AM
DharmenderGupta
Hi All,
I have created an Enterprise Geodatabase in Oracle 11g DB.
When I try to register this DB with Arc GIS Server either from arc gis desktop or arc gis manager it says "The file path does not exist or is too long (> 512 chars) or has invalid characters .]
Can anyone let me know what could be the reason for this.
Thanks in advance..
TinaMorgan1
Hello, I see this is an older post, but just wanted to check if you were able to call Esri Support and find a resolution to this issue?    If you were able to get around the issue (either with or without support), do you have the details that helped you move forward?
Sincerely,
TM
