UK Postcode/ZIP - New and a bit lost...
5241
10-26-2012 07:05 AM
HannahKirk
Hi all,
I read in the FAQ:
Can I geocode UK Postcodes directly in ArcGIS Online?
You can add features from a delimited text file (.txt) or comma-separated values text file (.csv) that contains Postcode information.
If you are using a Personal account you can geocode a file containing up to 250 addresses by adding it directly into your web map.
If you have a Subscription you can create a reusable geocoded dataset by publishing a hosted feature service. There is no limit to the number of addresses you can geocode via this method.
However I've not been able to. I find it is only picking up the first half of my postcode so I lose a lot of data.
Do you have any suggestions?
Thanks so much!
Hannah
SarahOsborne
Esri Alum
Currently, you can only geocode using the first half of the postal code.  In the December release of ArcGIS Online, you'll find that you will be able to geocode the entire postal code in the UK.
SarahOsborne
Esri Alum
HannahKirk
Thanks so much sarahoo, that is wonderful news and very helpful as it saves me finding a work around! Very much appreciated
DanEvans
*EDIT* If you have access to ArcMap: *EDIT*
Another way in the meantime would be to get the OS Code-Point Open data (it's free) from http://www.ordnancesurvey.co.uk/oswebsite/products/code-point-open/index.html
You get a point feature for each full postcode in the UK, simply join the data in your .txt or .csv file to it based on the postcode, selecting to only keep matching features, and your data is geocoded to full postcode level.
You might need to play around with the codes as the OS data doesn't have a space between the incode and outcode where the first number has two digits, e.g. LS4 2DD and LS153EF. I've found the best way to do this is to create new fields for incode and outcode and use the field calculator to separate them before recombining them according to how your data is formatted.
Hope that helps...
Dan
HannahKirk
Wonderful, Dan! We will certainly look in to this!! It seems like a straightforward enough way forward.
Hope that helps...
Dan
