Truncate Address in String Field
1363
10-24-2012 06:30 AM
StevenSmith1
I would like to remove city codes from the end of addresses that need to be geocoded and was wondering if there's a simple field calc formula to do this?
For example looking to take 123 Main St-AABB and calculate 123 Main St into a new field removing the city code AABB.
I have over a thousand addresses so going through deleting by hand is not an option.
by Anonymous User
Not applicable
If every record has the city code after the address separated by a dash, this can be done very easily with the field calculator.  Set the parser to Python and put in this expression:
!field_name!.split("-")[0]
This will return everything before the dash, in your case "123 Main St"
StevenSmith1
Thank you!
I was trying that but without the [0] at the end and it wasn't working.
I did end of getting the same result from using a combination of the InStr() to find location of "-" then Left ([fieldname], [InStr] -1) but this is one less step and faster.
Thank you again for all your help!
