Topology Toolbar Question
1318
07-23-2012 07:49 AM
MatthewPriester
I have a quite a few errors on a shapefile I'm trying to edit. Whenever I go to the topology toolbar and click on the Fix Topology Error Tool it does not let me click it. The only things I can click on are construct polygons and split polygons. I have a full license so I should be able to use this toolbar. I'm sure there is a really simple explanation and that I'm just overlooking something here.
Thank you in advance.
JohnSobetzer
Honored Contributor
If your Select Topology is set to map topology then the Fix Topology button would be grayed out.
MatthewPriester
Thank you for your reply, I'm still new to this.
