problems with spatial adjustment tool, using on features converted from CAD to gdb
2172
09-22-2011 12:37 PM
KirstenLawrence
I've created a new fgdp and imported the CAD drawing I wish to georeference. I then loaded the data into a map with layers that are in my desired projection, and created some links. When I try to adjust, it processes for a second, then does nothing - the links disappear but the features remain in the same place. What could be wrong? I've checked the coordinate system of the map and the layers, they are set the same.
CarrieGuiles
I have the exact same problem - have tried multiple iterations including unprojected (no projection defined), projected in target coordinate system, saving and importing links...you name it.  Any super-savvy users out there want to comment?
