Topology Toolbar - editing
1494
08-13-2012 05:36 AM
Bård_AndreasLassen
Hi, I have just started using ArcMap, and now I am trying til learn how to use the topology toolbar.
I hope somebody can help with my problem:
When I am trying to check the check box for my shapefile in the Map Topology dialog box, the frame seem to be grayed out. I am still able to check it.[ATTACH=CONFIG]16874[/ATTACH]
The result of this seems to be that I not able to use the editing tool on the Topology toolbar. Except the Map Topology button, they are all grayed out.
Any suggestions?
Bård
by Anonymous User
Not applicable
I believe the features that you want to participate in topology need to be feature classes in a geodatabase.  Shapefiles are not supported with topology as far as I know.  Try importing the shapefiles into a gdb and it should work for you.
Caleb
