Time enable a jpg
1353
03-11-2019 03:07 AM
NicholasPortnell
Hello,
I am trying to add an individual jpg (a photograph not georeferenced) within data view, AND then enable time on it so it can be controlled within the time slider to appear within a time window.
Thanks in advance.
NicholasPortnell
Dan,
Thanks again. Have solved issue by doubling a point feature then offsetting one and changing it to a 'picture symbol' then adding a date field to attribute table.
DanPatterson_Retired
So you don't have a mosaic dataset? Just one raster?
How time is supported in spatial data—ArcGIS Pro | ArcGIS Desktop
Set the time properties on data—ArcGIS Pro | ArcGIS Desktop
How do you want to enable time?
NicholasPortnell
Thanks for the speedy response Dan. To answer your questions:
- It is a single jpg (Photograph of an incident) not a dataset, I need to be able to store the photo whilst adding temporal data.
- I would like to use the time slider functionality to play and export a video of this photograph along with other time enabled features (already applied) but only have the photograph appear within a specified time window.
NicholasPortnell
Dan,
