The selected Object Failed to draw: Network I/O Error
1725
02-23-2013 12:19 AM
EmadAl-Mousa
we are receving a feature class through replication from another department within our organization, this feature class is within a feature dataset. all of the other feature classes are working fine execpt this one.
whenever you try to display it from "geography" dispaly the following error is being displayed:
The selected Object Failed to draw: FEATURE CLASS NAME : Network I/O Error
our environemnt:
ArcSDE 10.0 Service Pack 5
Server:IBM AIX 6.1
Database: Oracle 11g R2 (PSU 11.2.0.3.4)
The ArcGIS Desktop used to view the feature class ( we used both ArcGIS 10.0 & ArcGIS 10.1 Desktop) with the same error.
EmadAl-Mousa
i found out that most probably the issue is realted to "spatial index". you need to re-create it or re-replicate the feature class.
Also, its worth mentioning to check your ATTRBUFSIZE parameter in server_config table you may need to increase it if you have large data records.
EmadAl-Mousa
