The latest ST_GEOMETRY and dependent libraries need to be copied to the correct softw
2966
02-18-2014 06:10 AM
EmadAl-Mousa
i am upgrading my geodatabase instance from 9.3.1 to 10.1
my environment:
Oracle 11gR2 (11.2.0.3)
ArcSDE 9.3.1 SP2
IBM AIX 6.1
i want to enable st_geometry on my instance, i have followed esri procedure, however every time i run the pre-requisite upgrade tool i still face the warning message "The latest ST_GEOMETRY and dependent libraries need to be copied to the correct software location"
i have used the geoprocessing tool "create spatial type", and used the "sys" user (which is by the way not a good security practice to access a 'sys' user from the client, which requires the creation of a password file,...etc)
the tool ran for 3 seconds and stated "successful" message, however it gave me a warning that a "geodatabase instance already exists".
i have copied the st_shapelibrary.so from $SDEHOME/lib to under my $ORACLE_HOME/lib
also i have updated the external procedure file under $ORACLE_HOME/hs/admin
with a directory referencing the $ORACLE_HOME/lib/st_shapelibarary
is this the right path where should i place the library ?
or should i place it locally on my machine where ArcGIS desktop ? if this is the case.....can someone please provide the directory?
VinceAngelo
Esri Esteemed Contributor
Do not copy anything from SDEHOME.  The most recent libraries are part of the
Desktop unstall (under the Desktop10.1/DatabaseSupport/Oracle folder, as
described by the  documentation).  You should apply 10.1 SP1 before copying.
- V
VinceAngelo
- V
EmadAl-Mousa
i found the st_geometry libraries in the following directory:
C:\Program Files (x86)\ArcGIS\Desktop10.1\DatabaseSupport
