The ArcSDE(64 bit)'s bug: ORA01480 ?
1790
6
07-19-2010 10:52 PM
szcszc
Oracle: 10.2.0.4, 64 bit
ArcSDE: 9.3.1, 64 bit
OS: Windows Server 2008, 64 bit
When I import vector datas into SDE Geodatabase, and the type of geometry field is ST_Geometry,
then the ORA01480 error appears.
I ask an esri stuff, he says that this is 64bit SDE' bug,  does the ArcGIS 10 have this bug?
huangJary
Me too, in this circumstance, the data can't be imported into SDE Database, when the type of shape field is ST_GEOMETY.
When the type of shape field is BLOB or SDO, the data can be imported succesfully.
Do you anybody know the reason?
VinceAngelo
Esri Esteemed Contributor
A search with "ORA-01480" turned up this bug report.  I avoided Oracle 10.2.0.4
and have moved on to 11g (11.1.0.7), and I haven't seen this problem.
- V
szcszc
- V
the version of ArcSDE is latest, and the version of oracle is 11.1.0.7.0,
in the third step the ORA-01480 error appear.
Oracle Database 11g Enterprise Edition Release 11.1.0.7.0 - 64bit Production
ArcSDE Version 9.3.1
ArcSDE Server Build for Oracle11g Build 3055 Mon May 10 10:12:50
2010
C:\Users\Administrator>sdetable -o create -t POI3 -d "OBJECTID integer,GLOBAL_ID
integer(10),MESH_ID string(10),POI_ID integer(10),POI_TYPE string(6),AD_CODE st
ring(6),NAME string(160),ADDRESS string(160),IMPORTANCE smallint(3),PIC_ID strin
g(24),TELEPHONE string(36),FAX string(36),POSTCODE string(6),BIRTHDAY string(15)
,COORD_TYPE string(1),DISPLAY_CLASS string(2)" ------(1)
C:\Users\Administrator>sdetable -o alter_reg -t POI3 -c objectid -C SDE -M 1 -N ------(2)
C:\Users\Administrator>sdelayer -o add -l POI3,shape -e p -k DEFAULTS -t ST_GEOM
ETRY ------(3)
ArcSDE 9.3.1 for Oracle11g Build 3055 Mon May 10 10:12:50 2010
Layer Administration Utility
Error: Underlying DBMS error (-51).
Error: Cannot Create Layer.
ORA-01480: trailing null missing from STR bind value
VinceAngelo
Is your database 10g or 11g, or did you have this problem with both databases?
I rarely use 'sdelayer' to create geometry columns. I wonder if the problem is
more with 'sdelayer' than the underlying SE_layer_create API call.
I'm also wondering if it has to do with the lack of coordinate reference information
(no "-G" and "-x" [or "-R"]). What happens if you define a proper coordref?
The 'sdelayer' command accepts a flag to register the rowid column during
'-o add' -- what happens if you skip the 'sdetable -o alter_reg' and just add
"-C objectid" to 'sdelayer -o add'?
The objectid column is required to be NOT NULL -- what happens if you
define it that way with 'sdetable -o create'?
- V
szcszc
- V
My Oracle Database is 11g, The proplem appears only if ArcSDE is 64bit
The error appears also when  I using ArcCatalog.
C:\Documents and Settings\hongwei.yu\sdetable -o create -t POI2 -d "OBJECTI
D integer NOT NULL,GLOBAL_ID integer(10),MESH_ID string(10),POI_ID integer(10),POI_TYPE s
tring(6),AD_CODE string(6),NAME string(160),ADDRESS string(160),IMPORTANCE small
int(3),PIC_ID string(24),TELEPHONE string(36),FAX string(36),POSTCODE string(6),
BIRTHDAY string(15),COORD_TYPE string(1),DISPLAY_CLASS string(2)" -i 5153 -s 172
.20.2.9 -u SDE -p ACCPTest
ArcSDE 9.3 for oracle 11g Build 1632 Thu Feb 26 12:05:37 2009
Attribute Administration Utility
Successfully created table POI2
C:\Documents and Settings\hongwei.yu\sdelayer -o add -l POI2, shape -e p -k DEFAULTS -C objectid ,sde,1,-t ST_GEOMETRY -R 3 -i 5153 -s 172.20.2.9 -u SDE -p ACCPTest
Error: Underlying DBMS error <-51>.
Error: Cannot create Layer.
ORA-01480:
huangJary
The proplem is the bug of ArcSDE 64bit, it appeared two years ago, but ESRI hasn't modified this bug up to now
