Terrible SDE Performance
4243
9
03-10-2011 04:33 AM
ChrisMcKee
Hello...
Just wondering if anyone has any insight into extremely poor performance after the following scenario:
Update a portion of a large dataset:
  1. Delete features
  2. Load in new features
Attempted solutions:
  • Recalculate spatial grid
  • Analyze tables (Business, Feature, Adds and Deletes)
Following loading the new data it will literally take a full minute to draw the entire dataset (not just the new parts).  Before the new data was deleted/added, it would draw in a few seconds.
I really don't want to have to create a new feature class and swap them out, it's bit of pain, especially when I want to automate the entire process.  I just need to get past this awful performance.
We are using SDE 9.3.1 on SQL Server
Forrest
VinceAngelo
Esri Esteemed Contributor
What tool(s) are you using to make the changes?
Is the table versioned?
What geometry storage option are you using?
How many rows are involved (total, deleted, & inserted)?
What is the envelope which is defined for the layer? What is the actual envelope
of features in the dataset?
"Draw entire dataset" should be pure database operation, which is dependent solely
on the size of the database cache and the number of rows to return.
- V
ChrisMcKee
  • My first test was manually deleting a portion of 'parcels' in an edit session
  • My second test was to empty the entire feature class using 'Delete Features' tool in tbx
  • To load in the new ones I literally did a 'load data' by right clicking the FC.  I will eventually be using the Append tool in the tbx.
  • Yes
  • These are relatively simple, projected polygons, though some have a large number of vertices
  • Total parcels 100,000+/-.
  • High number of changed would be 50+ thousand, but I have seen the same performance when simply swapping out 100+/-.
  • As these could be part of a regional update or entire provincial update the envelope would be different every time.  For this example think large and small scale envelopes.
Forrest
VinceAngelo
Old questions, revisited:
   SDEBINARY or GEOMETRY/GEOGRAPHY?
   I'm looking the actual layer envelope and MBR of *all* features. The purpose here
is to determine if a "draw all features" is doing a spatial query (it shouldn't, but an
incorrect layer envelope could throw off the ArcSDE optimizer).
New questions:
Since your table is versioned, how often do you reconcile and post features to the
base table?  What is the total row count in your A and D tables?
What is the average number of vertices per feature ('sdelayer -o stats' output)?
How is your coordinate reference defined ('sdelayer -o describe_long' output)?
- V
ChrisMcKee
Sorry I mis-interpreted the question.... we are using SDEBINARY
What is the envelope which is defined for the layer? What is the actual envelope of features in the dataset?
  • This sounds promising but I am not sure how to check the actual envelope.  Are you referring to the spatial envelope?
  • [INDENT]
  •                 minx:  -1479597.40040,  miny:    505471.22000
  •                 maxx:   2269595.76810,  maxy:   2067275.29180[/INDENT]
Well currently this is a new feature class so it is only in testing... However, between emptying and reloading I analyzed the tables so the A&D's should have been cleared, as well, after the load I analyzed so they should not have been the issue.
  • Minimum Feature Number:                  1
  • Maximum Feature Number:             407635
  • Largest Feature:                      9565 Points
  • Smallest Feature:                        4 Points
  • Average Feature:                     19.87 Points
  • Minimum Polygon Area:                           0.00484 sq.
  • Maximum Polygon Area:                    71092824.10687 sq.
  • Average Polygon Area:                      111215.02587 sq.
  • Minimum Polygon Perimeter:                      0.44173
  • Maximum Polygon Perimeter:                  68832.04798
  • Average Polygon Perimeter:                    844.16128
  • ArcSDE 9.3.1  for SQL Server Build 3056 Fri Sep 10 09:41:17  2010
  • Layer    Administration Utility
  • Layer Description ....: <None>
  • Database              : CLIENT_NAME
  • Table Owner ..........: CLIENT_NAME
  • Table Name ...........: CLIENT_NAME_PARCELS
  • Spatial Column .......: SHAPE
  • Layer Id .............: 42
  • SRID .................: 1
  • Minimum Shape Id .....: 1
  • Offset ...............:
  •   falsex:  -16688100.000000
  •   falsey:   -9068200.000000
  • System Units .........:      10000.000000
  • Z Offset..............:          0.000000
  • Z Units ..............:          1.000000
  • Measure Offset .......: <None>
  • Measure Units ........: <None>
  • XY Cluster Tolerance .:          0.001
  • Spatial Index ........:
  •   parameter:    SPIDX_GRID,GRID0=940,GRID1=5640,FULL
  •   exist:        Yes
  •   array form:   940,5640,0
  • Layer Envelope .......:
  • Entities .............: nac+
  • Layer Type ...........: SDE
  • Creation Date ........: 02/09/11 16:15:12
  • I/O Mode .............: NORMAL
  • Autolocking ..........: Enabled
  • Precision.............: High
  • User Privileges ......: SELECT, UPDATE, INSERT, DELETE
  • Coordinate System ....: PROJCS["North_America_Albers_Equal_Area_Conic",GEOGCS["G
  • CS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",637813
  • 7.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],P
  • ROJECTION["Albers"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",0.
  • 0],PARAMETER["Central_Meridian",-105.0],PARAMETER["Standard_Parallel_1",20.0],PA
  • RAMETER["Standard_Parallel_2",60.0],PARAMETER["Latitude_Of_Origin",40.0],UNIT["M
  • eter",1.0]]
  • Layer Configuration ..: CLIENT_NAME_VECTOR
Forrest
VinceAngelo
There are many ways to obtain the actual envelope, including zooming to the window and
writing down the LLx/y and URx/y, and using 'sdelayer -o alter -E calc'. Is your dataset really
10:1 in width:height? (2000km x 200km)
Your vertex count is relatively small, but you might see performance savings by using
an xyscale of 1000 (millimeter precision) or 100 (centimeter precision) vice the 0.1mm
default.
The minimum area indicates a *parcel* of 0.005 square meters (roughly 3"x3") -- that seems
questionable (not many lots sold with the fooprint of a fencepost -- how would you keep out
trespassers? 😉
- V
ChrisMcKee
  • minx: -1,500,000m
  • maxx: 2,300,000m
  • miny: 500,000m
  • maxy: 2,070,000m
  • =3,800km(x) x 1,570km(y)
  • It's basically an amalgamation of all of our parcel datasets for a single continuous dataset.
default.
  • To alter this precision do I have to reload the data (create new feature dataset) or can I do it once it's already in there?
trespassers? 😉
  • They are just really small fence posts or 'slivers'...lol
VinceAngelo
My bad. I parsed the coords minx maxx\n miny maxy.
Coordinate references are fundamental properties, determined at layer creation; you'd
need to reload to change the precision.
- V
ChrisMcKee
Do you see anything inherently wrong in how this is setup that would cause performance issues only after data is emptied and reloaded?
I'm just at a loss because when I analyze tables I would expect this would be resolved but it isn't.
When I select the layer to 'preview' it take a long time before it even begins to draw, let alone draw.  Is there something wonky about the indexing or it's ability to start querying the data?
VinceAngelo
It's time to open an incident with Tech Support. Be sure to provide them the exact
versions of software (both Esri and database., to the service pack or patch level).
They'll need a copy of the dataset and the exact steps you're taking as well.
- V
