Terrain Hillshade basemap not displaying in PDF ?
1689
01-21-2020 09:57 AM
DEAF_PROBERT_68
Honored Contributor
When I make a map and I add Terrian Hillshade as a basemap.
So when I export it to PDF,  the Terrain hillshade basemap did not show up ?
What might go  wrong here ?
I'm using it ArcGIS 10.5.1 in Citrix
Thanks
Tags (3)
DEAF_PROBERT_68
Honored Contributor
The one I wanted to use Terrain Hillshade to my ArcMap in Citrix. Here is the link:  https://www.arcgis.com/home/item.html?id=c3587bd89d474dff8d306fefdc295083
Though, I was able to login to my AGOL in ArcMap to use it in Citrix.
It seems that my ArcMap in Citrix doesn't like terrain hillshade  for some reasons...but I went over to ArcGIS Pro and import it from the Citrix side and was able to export to PDF fine...
I have test other different basemaps and I have tried to export them in ArcMap Citrix and they worked but not this terrain hillshade.
I think it has a lot to do with block to export to PDF , or perhaps I need to have projection all the layers to align with the terrain hillshade ?
DEAF_PROBERT_68
Honored Contributor
