Tec DEM Import problems
679
10-16-2011 06:40 AM
TylerDoane
I'm trying to import DEMs to Tec DEM as a geotiff.  I'm able to successfully export from Arc, and it says that the DEM loads successfully in Tec DEM.  But when I run processes, no data is generated.  Any thoughts?
FaisalShahzad
There is some problem between the standard geotiff file format and the one exported from ArcGIs.
I will suggest you to use another image processing package to export your geotiffs. This will solve the problem for loading your data in TecDEM.
