Hi Peter,It may be easiest to do this using a python script rather than model builder. Here is an example on how to do this. The below script will iterate through each sub directory in your 'H:\Projects\H107039_PeterW\workpackages' workspace:import arcpy, os
from arcpy import env
folder = r"H:\Projects\H107039_PeterW\workpackages"
for (path, dirs, files) in os.walk(folder):
if ".gdb" not in path.lower():
env.workspace = path
databases = arcpy.ListWorkspaces("*", "FileGDB")
for database in databases:
arcpy.TableToDomain_management(r"C:\TEMP\Python\domain.dbf", "Code", "Desc", database, "City")You will just need to update the line "arcpy.TableToDomain_management(r"C:\TEMP\Python\domain.dbf", "Code", "Desc", database[0], "City")". The first variable is the path to the table containing the domain. The second variable is the field containing the domain code. Third variable is the field containing the domain description, and the 5th variable is what you would like to name the domain.
