Synchronize Replica failed Out of client memory
1046
10-01-2013 08:31 AM
AgnesPoirier
I'm trying to synchronize with one-way replication using ArcGIS 9.3.1 SP2 , Arcsde9.3 Oracle 10g.
Recently, I got the following message everytime I'm running the replication using
ArcSDE  Connect or ArcSDE Direct Connect , the replication was previously working fine.
Synchronize Replica Failed
Version not found[IRSDE.GVAHUB_PROD]
OK
Each time I try to run again the replication , it is restarting again the same processes as  they haven�??t been completed from the previous replication and it always stopped without finishing with an error.
The errors can be found GDB_REPLICALOG table  as followed
ID REPLICAID EVENT ERRORCODE LOGDATE SOURCEBEGINGEN SOURCEENDGEN TARGETGEN
368 131 2 -2147217147 12-SEP-13 16 17 0
376 131 2 -2147217147 17-SEP-13 17 18 0
377 131 2 -2147467259 17-SEP-13 17 18 0
384 131 2 -2147212963 17-SEP-13 0 0 0
385 131 2 -2147212963 17-SEP-13 0 0 0
386 131 2 -2147467259 17-SEP-13 17 18 0
379 131 2 -2147467259 18-SEP-13 17 18 0
391 131 2 -2147467259 18-SEP-13 17 18 0
393 131 2 -2147467259 19-SEP-13 17 18 0
394 131 2 -2147467259 19-SEP-13 17 18 0
392 131 2 -2147467259 19-SEP-13 17 18 0
396 131 2 -2147467260 19-SEP-13 17 18 0
398 131 2 -2147467259 19-SEP-13 17 18 0
399 131 2 -2147467259 23-SEP-13 17 18 0
400 131 2 -2147467259 27-SEP-13 17 18 0
This replication is updated huge polygons with lots of points.
Do you have any ideas of the reasons of this failure?
Where can I can the description of the errorcodes available in the GDB_ERRORCODE?
Could it be a corruption of the layers?
Thanks for your help
