Synchronize Mosaic Dataset with Only a Subset of Sources Tables
1073
09-21-2017 07:42 AM
GeorgeNewbury
Was wondering if anyone has experience synchonrizing a mosaic dataset with only a subset of source tables/folders. For example I have
Three source mosaic datasets:
..\A.gdb\Mosaic1
..\B.gdb\Mosaic1
..\C.gdb\Mosaic1
And one derived mosaic dataset
..\All.gdb\Mosaic1'
The 'All.gdb\Mosaic1' has all of the rasters that are in the three source mosaic datasets. The three source mosaic datasets were initially added to the derived mosaic dataset using the 'Table' raster type.
Now when I add new rasters to one of the source mosaic datasets, i.e '\C.gdb\Mosaic1' I would like to synchronize it with the derived mosaic dataset. However, I don't want to waste time also synchronizing with the other sources as 1.) they may be huge and 2.) I know nothing has changed. If I use a where_clause when I synchronize to a raster in the desired source mosaic dataset, will it add new items from the source's table?
Thanks
George
