BTW, The replica creation is successful... the problem is with the synchronization process... 😞
Here are what I did :
1. I created a featureclass, lets call it FC1, in master database. Then i edit FC1, add new objects then save. Then i click "Create Replica Wizard" with option "Data". Then i click "Synchronize". The new featureclass,FC1, and its objects are copied to the child database during synchronize.
2. I do editing on FC1 again on master database and save it. Then i click Create Replica with option "Register Existing Data Only" (as its already been created in step 1), then click "synchronize". The new object are not copied into FC1 in the child database.
The master and child database are exactly the same. I cold-back-up it. The child database is functioning perfectly, i can do editing,query,analysis, etc...
thanks
