Sudden crippling slow down in ArcMap...
1073
01-25-2013 12:49 PM
JohnNiles
I am attempting to edit topology of polylines and polygons in ArcMap. Seemingly unprovoked, any action I take that involves redrawing the layers takes upwards of five minutes. Topology can no longer be validated at it "runs out of memory". There's a whole lot of "Not Responding".
Please, please, please any idea of what happened?? I have attempted to rebuild the mxd, but the problem persists. I have installed the service packs, and done several other "tricks" suggested in the forums.. I can no longer work.
I can't even close ArcMap and start over - not even End Process closes it... PLEASE HELP!!!
EDIT: The problem quickly got worse - even previewing the feature class caused ArcCatalog to seize up required reboot to close. Seems I can no longer access the file at all. I have tried "Repairing Geometry and "Feature Class To Feature Class" in a new geodatabase.
HELP!
MarkBoucher
Honored Contributor
If you are working with the data over the network, you will get much less performance than if you work with the data on you local drive.
