Subtype order
1280
03-22-2011 08:42 AM
NickHarrison
We've come across an interesting issue with the use of subtypes. We are using ArcSDE 9.2 on oracle with ArcMap 9.2. We plan to upgrade to 10 later this year.
When the subtypes in our geodatabase are exposed to the ArcMap user in an edit session the order of the subtylpe list in the featurclass table drop list is "apparently" random. They are not displayed in numeric subtype order or in alphabetical order of the subtype text.  I did a little digging into the SDE GDB tables and discovered that the order seems to be based on the order of the actual data in the GDB_Subtypes table. This was probably the way the data was loaded.
We have implemented a featureclass with a fairly large number of subtypes and the editors are now complaining that the order they have to deal with is confusing. And I completely agree with them. The only way I can see to resovle this is to drop the subtype completely and manually add the values in the correct order via ArcCatalog, or surgically do the same via SQL. ...Not exactly the type of operation you want to do on an enterprise database... and one that cannot be done now that the data are in production. The order apparently got messed up during implementation from Visio,
Could I drop the subtype records from the GDB_Subtypes table and add them back in via SQL? If this were to work it would be the simplest solution. But I don't particularly like having to edit SDE/GDB tables with SQL.
Are there any plans to implement the ability to order the return of subtype values? Or has it already been done in ArcGIS 10?
You could begin to implement this by adding an order column to the GDB_SUBTYPES table and then get ArcMap to use that value. Or at the very least have the option somewhere in the GDB design to order the values by either the code or the text.
While I'm on the topic I might add that modifying the order of Domain values is no piece of cake either.
Nick Harrison
City of Calgary
/* SQL Query to return all Subtype values in the Geodatabase */
select GDB_OC.owner,
  GDB_OC.name as "FEATURE CLASS",
  GDB_S.Subtypename as "SUBTYPE TEXT",
  GDB_S.subtypecode as "SUBTYPE CODE"
from  SDE.GDB_OBJECTCLASSES GDB_OC,
  SDE.GDB_SUBTYPES    GDB_S
where GDB_OC.ID =   GDB_S.CLASSID
KeithAnderson
Totally Agree! It doesn't happen often but when it does its a pain to re-order. Store our lists in a Excel/Access table and import the sorted table on large sets.
Not fixed in 10. Will mention to ESRI formally.
Keith Anderson
LOGIS GIS
StevenRehbaum
Just went through this exercise rebuilding an entire database with 23+ domains and every feature class has multiple subtypes including some with upwards of 14.  Horrible structure IMO.  Reordering all the subtypes was not fun at all.
