Strange behaviour with ST_INTERSECTS
8046
11
02-05-2014 11:02 PM
StefanoIacovella
Dear all,
I am experiencing a strange behaviour with ST_INTERSECTS.
The environment is as follow:
ArcSDE 10.1 SP 1 on Oracle 11.2.0.3 64-bit
Red Hat server
ST_LIBRARIES is correctly deployed and configured.
When I run the following query I got an error:
SQL*Plus: Release 11.2.0.3.0 Production on Thu Feb 6 09:51:59 2014
Copyright (c) 1982, 2011, Oracle.  All rights reserved.
Connected to:
Oracle Database 11g Enterprise Edition Release 11.2.0.3.0 - 64bit Production
With the Partitioning, Real Application Clusters, Automatic Storage Management, OLAP,
Data Mining and Real Application Testing options
SELECT
    IBOW.SEAGRASS_RL13.OBJECTID,
    IBOW.SEAGRASS_RL13.RLSTATUS
FROM
    IBOW.SEAGRASS_RL13,
    IBOW.ITALYF2_REV1_AU
WHERE
    SDE.ST_INTERSECTS (IBOW.ITALYF2_REV1_AU.SHAPE, IBOW.SEAGRASS_RL13.SHAPE) = 1;
SELECT
ERROR at line 1:
ORA-28579: network error during callback from external procedure agent
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 100
ORA-06512: at "SDE.ST_RELATION_OPERATORS", line 340
Running the query on a small subset of features works:
SELECT
FROM
    IBOW.SEAGRASS_RL13,
WHERE
    AND IBOW.SEAGRASS_RL13.OBJECTID IN (27);
  OBJECTID  RLSTATUS
        27      LC
My guess is that probably the external process run out of memory when pperforming the intersect on many features. Is there a way to check for the error in the external process?
Thanks in advance for any hint.
Kind Regards,
Stefano
StefanoIacovella
Hi Stefano,
Are you using 11.2.0.3 or 12.2.0.3 (is this released yet)? From what I can tell it is fixed in a patch set on top of 11.2.0.2 and in 12.1.0.1. I suggest checking the info in this KB article and then following up with Oracle if you get an hs_core file as described:
KB38823 - Bug: Spatial Type for Oracle: st_intersects can fail with error ORA-028579
Otherwise yes, please open an incident with your local distributor.
Thanks.
Sorry, it was a typo, I mean 11.2.0.3.
I will check if the behaviour is like the one described in the Oracle bug.
Thanks for your support
Stefano
JeffPace
we are on 11.2.0.3 and experiencing this issue after the 10.2.2 upgrade.  Any solutions?
