Stereo Analyst for ArcGIS problems
72131
08-06-2012 12:45 PM
ZackAdkins
Help!!
I am using Windows7, ArcGIS 10.1 with the Stereo Analyst extension.  I am using the Planar Stereo Mirror (clone mode) set up with a NVIDIA 4500 with the latest drivers.  I can't get anything to display in the stereo window.  I have tried every possible setting.  This happened when I switched from Windows XP to 7 and ArcGIS 9.3 to 10.  Any suggestions?  Anyone else seeing this problem?  Please help!
-Zack Adkins
by Anonymous User
Not applicable
I am familiar with stereo analyst but have never used it.  You may have better luck finding an answer in the Defense and Intelligence forum since many of the users that work with stereo analyst are in that field.  Hopefully someone in there can help you.
johnbickmore1
Help!!
-Zack Adkins
Hi Zack
I am chasing the same info however I am currently on windows 7 using Arcgis 9.3.1 with quadro FX1800 with updated drivers and the planar is working perfectly.  We are about to upgrade to 10.1 and I was wondering if spatial analyst and 10.1 were compatible?
also re check your drivers that they support 3d and windows 7 - from memory we had to try a few different drivers after i upgraded from xp to 7.
John
LarryRobinson
Hi Zack
John
I realize this thread is a few months old but I had the same problem and wanted to let folks know that, according to ERDAS Support, ArcGIS 10.1 won't support Stereo Analyst for ArcGIS until SP5 is released.  They are planning to make SP5 available in "mid-January" so we should have this capability again any day now.
Larry
