ST_GEOMETRY problem
11926
07-01-2015 10:32 PM
GabitAlmenbetov
Hi guys,
I get following error when try to select from gdb_items_vw:
select * from gdb_items_vw;
ERROR:
ORA-28595: Extproc agent : Invalid DLL Path
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 1339
ORA-06512: at "SDE.ST_GEOM_UTIL", line 760
select st_point(0,0,0) from dual
ERROR at line 1:
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 12
ORA-06512: at "SDE.ST_POINT", line 176
We have Oracle Database 11.2.0.3 installed at RHEL and ArcSDE 10SP5 at Windows.
After some reading get confused how should I point to correct user library, the current shows this:
SELECT * FROM USER_LIBRARIES;
LIBRARY_NAME       FILE_SPEC  D STATUS
ST_SHAPELIB       C:\ArcSDE\ArcSDE\ora11gexe\bin\st_shapelib.dll  Y VALID
Should i download ArcSDE for Linux and extract from it Linux versions of library files and put it at Linux Server where Oracle database is?
OR just update extproc.ora with C:\ArcSDE\ArcSDE\ora11gexe\bin\st_shapelib.dll, because it didn't worked - the same result???
Tags (1)
GabitAlmenbetov
Hi All,
[PS. Thanks Vince Angelo, I didn't mean and don't at all and all times to offend anybody.]
So my solution was from:
1) ArcGIS Desktop
2) ST_GEOMETRY  problem on Oracle RDBMS 11g R2 11.2.0.3
So, my steps:
1) Downloaded ArcSDE10_UNIX_121100.iso, unpacked and get required files.
2) INSTALLING ORACLE AND ARCSDE ON SEPARATE SERVERS: [6] - Copy the st_shape shared library used by EXTPROC to the Oracle server.
[root@host /]# mkdir /arcsdehome
[root@host /]# chown -Rf oracle.oinstall /arcsdehome/
[root@host /]# cp -pr /tmp/sdeexe100/lib/libst_* /arcsdehome/
[root@host /]# ll /arcsdehome/
total 12920
-rw-r--r--. 1 oracle oinstall 7572806 Jul  2 11:23 libst_raster_ora.so
-rw-r--r--. 1 oracle oinstall 5652930 Jul  2 11:23 libst_shapelib.so
[root@host /]#
[oracle@host ~]$ cat .bash_profile
export SDEHOME=/arcsdehome
export LD_LIBRARY_PATH=$SDEHOME:$ORACLE_HOME/ctx/lib:$ORACLE_HOME/lib:$LD_LIBRARY_PATH
[oracle@host ~]$ echo $SDEHOME
[oracle@host ~]$ . ~/.bash_profile
/arcsdehome
[oracle@host ~]$
3) INSTALLING ORACLE AND ARCSDE ON SEPARATE SERVERS: [7] - Create the Oracle library entries for these ArcSDE libraries with the following SQL command as the ArcSDE administrative user (the sde user).
02-JUL-15:SDE()@dbname>column file_spec format a50
02-JUL-15:SDE()@dbname>SELECT * FROM USER_LIBRARIES;
1 row selected.
Elapsed: 00:00:00.03
02-JUL-15:SDE()@dbname>CREATE OR REPLACE LIBRARY st_shapelib AS '/arcsdehome/libst_shapelib.so';
  2  /
ERROR at line 1:
ORA-01031: insufficient privileges
02-JUL-15:SYS(AS SYSDBA)@dbname>grant create library to sde;
Grant succeeded.
  2  /
Library created.
Elapsed: 00:00:00.15
ST_SHAPELIB       /arcsdehome/libst_shapelib.so  Y VALID
1 row selected.
02-JUL-15:SDE()@dbname>CREATE OR REPLACE LIBRARY libst_raster AS '/arcsdehome/libst_raster_ora.so'
  2  /
Library created.
Elapsed: 00:00:00.07
LIBST_RASTER       /arcsdehome/libst_raster_ora.so  Y VALID
2 rows selected.
Elapsed: 00:00:00.01
4) INSTALLING ORACLE AND ARCSDE ON SEPARATE SERVERS: [8] - Configure the Oracle EXTPROC so it can find the st_shapelib and libst_raster_ora libraries.
[8.a] - Add the following entry in the tnsnames.ora on the remote database server: Actually I have added per official documentation but then removed per forum note(links are above).
[8.b] - Add the following entry to the SID_LIST in listener.ora on the remote database server:Actually I have added per official documentation but then removed per forum note(links are above)
[8.c] - Modify your extproc.ora as follows
SET EXTPROC_DLLS=ONLY:/arcsdehome/libst_shapelib.so:/arcsdehome/libst_raster_ora.so
5) Compile st_geometry_shapelib_pkg.
02-JUL-15:SYS(AS SYSDBA)@dbname>alter package sde.st_geometry_shapelib_pkg compile reuse settings;
Package altered.
Elapsed: 00:00:00.39
6) Creating the library causes dependent object to become invalid. Execute the following command as the SDE user (you may need to grant the execute privilege on sys.utl_recomp to user SDE)
02-JUL-15:SYS(AS SYSDBA)@dbname>GRANT EXECUTE ON SYS.UTL_RECOMP TO SDE;
Grant succeeded.
02-JUL-15:SYS(AS SYSDBA)@dbname>conn sde/************
Connected.
02-JUL-15:SDE()@dbname>EXECUTE sys.utl_recomp.recomp_serial('SDE');
PL/SQL procedure successfully completed.
Elapsed: 00:00:00.56
02-JUL-15:SDE()@dbname>select object_name, object_type from user_objects where status = 'INVALID';
no rows selected
Hope this procedure will help you in configuring your mixed environment!!!
Izgi niyetpen,
Gabit Almenbetov
JayantaPoddar
Hi Gabit,
Go to the ArcGIS install folder > database support. Copy the appropriate files from Oracle > Linux64
Paste it in the library of the Oracle installed in Linux. Restart the Oracle services.
Think Location
VinceAngelo
Esri Esteemed Contributor
Your situation is a bit more complicated than just following the 10.1/10.2/10.3 installation procedure.
It's been a long time since I last installed 10.0 sp5 DLLs in an Oracle instance, but I don't believe the DLLs shipped with ArcGIS Desktop until 10.1, so you'll probably need to find a Linux ArcSDE Server installation binary (the DLLs must match the architecture of the LISTENER binary -- 64 bit Linux, I assume).
Oracle significantly changed ExtProc configuration between when ArcGIS 10 was released and Oracle 11gR2.  The new (more secure) procedure may not work correctly with an elderly shapelib binary.  There are a number of Knowledge Base documents on Listener configuration.  I usually google them with the Oracle error message and "arcgis".
- V
PS: Please use a gender-neutral greeting in public forums.  There are plenty of non-"guys" who would be available to answer questions if you don't offend them.
GabitAlmenbetov
Hi All,
1) ArcGIS Desktop
So, my steps:
total 12920
[root@host /]#
/arcsdehome
[oracle@host ~]$
1 row selected.
  2  /
ERROR at line 1:
Grant succeeded.
  2  /
Library created.
1 row selected.
  2  /
Library created.
2 rows selected.
Package altered.
Grant succeeded.
Connected.
no rows selected
Izgi niyetpen,
Gabit Almenbetov
