ST_Functions and versioned environment
1096
07-13-2010 11:54 PM
MichalGasparovic
Hello, I'm relying quite a lot on using the ST_Functions in a lot of my web applications. so far, I could simplify things meaning that all the feature classes weren't versioned. Everything works quite nicely, it's much faster bypassing the arcobjects / webadf when altering the data.
It's been some time I've worked with versioned object classes in sde.... and from what I remember, in case I needed to access the versioned data via SQL, I had to create multiversioned views...there were some limitation in editing scenarios...(well, can't point it out now as it's been quite some time ago, 2y)
My question is : is this (creating mv views) the only way of accessing and editing the data using the SQL (+ST) functions?
Are there any documents describing working with the SDE via SQL ? Does any one of you have a relevant experience of performance and complexity of implementing this in real life situations?
Thank you for all your help
DallasShearer
If your data isn't versioned you don't need to create any mv views to work with ST_geometry. If your data is versioned you don't have to create mv views to work with ST_Geometry, you will just be missing the changes in the data from your Add and Deletes table.
Here is the help link for working with ST_Geometry functions and operators.
http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=An_overview_of_SQL_functions_used_with...
MichalGasparovic
thanks for the update...
well, that's the problem, I need to access/modify the features in A/D tables via SQL. I think there was a document called "Working with geodatabase with SQL".... I wonder whether there is an update or not...
update***
something like the following : http://proceedings.esri.com/library/userconf/devsummit09/papers/sql_and_gdb.pdf
KimPeter
There's a section in the ArcGIS help for using SQL with ArcSDE geodatabases. This is the first topic in that "book":
http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#/A_quick_tour_...
Within that section of the help is information on multiversioned views (such as this topic)
http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#/Creating_mult...
...and a subsection on editing with SQL:
http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#/What_type_of_...
MichalGasparovic
Pete, thank you for those links ! that was exactly I was looking for 😉
