SRID / AUTH SRID?
3539
06-17-2013 05:58 PM
runegullstrom
I'm confused about which one to use, SRID or the AUTH_SRID. I want to create a feature class using a srid from another existing feature class. We use ST_GEOMETRY, so my assumption is to use the SRIDS in the ST_SPATIAL_REFERENCES table. I can also see that the existing feature class has this SRID in the ALL_ST_GEOMETRY_COLUMNS_V view. When I try to use it with "sdelayer -o add" I get the message.
Error: Spatial reference entry does not exist (-255).
Error: Error in getting spatial reference info object
I do a describe long on the feature class I try to copy the SRID from and see:
SRID .................: 10
Auth SRID.............: 33
Ok, fine, I'll use 10 instead and the layer is successfully created.
Then I'll query the layer with sde.st_intersects using SRID 10 at which point I get the message:
Parameter ST_SRID 10 does not exist in ST_SPATIAL_REFERENCES table.
Yes I know that, but I wasn't able to create it with 33. So what is it, SRID or AUTH_SRID?
regards,
Rune
Windows Server 2008, Oracle11g, SDE10 (no sp)
VinceAngelo
Esri Esteemed Contributor
It's both, as you've explained.  One is for sdelayer execution, the other is for SQL.
They are not interchangable.
- V
