SqlWorkspaceFactory deprecated in 10.1??? error -2147180283
3337
08-24-2015 01:39 PM
MarceloJury
Hello
Can anyone help me with this issue?
I have an instance sde:oracle11g and I'm trying to make a simple select from sample taken from here, using
     SqlWorkspaceFactory but cannot understand ERROR CODE -2147180283
Imports ESRI.ArcGIS.Geodatabase
Imports ESRI.ArcGIS.esriSystem
Imports ESRI.ArcGIS.ADF.Connection.Local
Imports ClassLibrary1.GenericObjectPoolVB
Imports ESRI.ArcGIS.Geometry
Dim con2 As IWorkspace = (I have an object pool here that returns me propper workspace object, and I name it as con2)
Dim sqlWorkspace As ISqlWorkspace = CType(con2, ISqlWorkspace)
' Construct a SQL query.
  Dim queryBuilder As StringBuilder = New StringBuilder()
  queryBuilder.Append("SELECT * ")
  queryBuilder.Append("FROM " + listView1.FocusedItem.Text)
  Dim query As String = queryBuilder.ToString()
  Using comReleaser As ESRI.ArcGIS.ADF.ComReleaser = New ESRI.ArcGIS.ADF.ComReleaser() 'is this correct reference? deprecated?
      ' Create the query cursor.
       Dim featureCursor As IFeatureCursor = CType(sqlWorkspace.OpenQueryCursor(query), IFeatureCursor)
       comReleaser.ManageLifetime(featureCursor)
     ' Iterate through the features.
       Dim feature As IFeature = featureCursor.NextFeature() ' HERE ERROR IS COMException was unhandled ERROR CODE -2147180283
MarceloJury
Hello, I've discovered this issue, and was related to a wrong oracle client installation, in fact a mismatched version, the reason to post was just a confusing ERROR CODE -2147180283.... thanks anyway.
