SQL Server windows authenticated user seeing all objects in ArcCatalog
3217
6
02-23-2017 09:21 AM
ScottNoldy
Details:
SQL Server 2014, 10.4.1 geodatabase.
I am the admin of the geodatabase (SDE user created, not dbo) using a SQL Server login.
When I connect via ArcCatalog I see all the feature classes, relationship classes and sde tables.
Most of these objects are registered as versioned.
I added a windows group to the database in SQL Server with nothing but the public role and went through, via ArcCatalog, and granted them permissions to all these objects.  When a user in that group connects they're seeing all the _evw views from the versioned datasets along with everything I can see above.
What did I do wrong that they can see all these objects in Catalog?
George_Thompson
Esri Notable Contributor
Did you only give them "Public" under the Server roles?
What are their permissions in the database for the User Mapping?
Geodatabase
--- George T.
ScottNoldy
Yes, I only gave them public when adding to the database.
I actually didn't give it to them, that's the default that you can't unselect.
ManviLather1
In SQL Server management studio,
Right click on the database -> properties -> permissions -> select the user-> click on effective and check the permissions granted to the user.
Also, please have a look at the below links:
http://desktop.arcgis.com/en/arcmap/10.4/manage-data/gdbs-in-sql-server/privileges-sqlserver.htm
http://desktop.arcgis.com/en/arcmap/10.4/manage-data/gdbs-in-oracle/grant-dataset-privileges.htm
ScottNoldy
It's a windows group so it's not possible to get effective permissions.
I used the change privileges tool to grant permissions to the windows group via arccatalog.
No permissions were granted via SQL Server.
ManviLather1
Check if group have "select" permission
ScottNoldy
No,connect is the only thing selected in the database permissions list.
