SQL Server spatial queries and ArcSDE data types
3460
05-28-2013 11:33 AM
AndrewHayden1
I'm playing around with doing some basic sql server spatial queries on arcsde feature classes (in ssms) and have had some success working with polygons.  I'm having trouble when I start querying points.  I'd like to do a basic point in polygon query using STIntersects or STWithin.  When I select the point layer I want to use I get a message saying "cannot call methods on int" (STWithin).  When I look at the feature class in catalog, it tells me the shape field type is "geometry."  When I look at it in ssms, it shows the field type as "int."  I try to cast the field as geometry in my query but I get a message saying explicit conversion from int to sys.geometry is not allowed.  I'm curious if anyone has insight on the int vs geometry datatype between ssms and arcgis and how I can handle the int type for a point feature class?
VinceAngelo
Esri Esteemed Contributor
SDEBINARY storage geometry layers are not visible to non-ArcSDE clients.  You'd need
to copy the layer to a new table using GEOMETRY or GEOGRAPHY storage (using a version
of ArcGIS compatible with the database, of course).
There's a ton of documentation to be had on this topic -- this link will put you in the right
general neighborhood.
- V
