SQL Server Next_RowID Stored Procedure
4539
03-26-2013 03:22 PM
BrandonCales
I'm trying to execute the next_rowid stored procedure based on the ArcGIS help, however SQL 'Could not find stored procedure 'dbo.next_rowid''
Anyone know where I can find the script to create the stored procedure?
http://resources.arcgis.com/en/help/main/10.1/index.html#/in_SQL_Server/006z00000017000000/
MarcoBoeringa
What version of ArcGIS / ArcSDE are you using? Support for SQL is a new thing in 10 and extended in 10.1. It may be that the stored procedure you are trying to use does not exist in your geodatabase until a future upgrade to 10.1. Please note that an upgrade of an existing geodatabase is a separate operation from upgrading your client PC's ArcGIS for Desktop application. You may be running ArcGIS 10.1 locally, but still be connecting to a 10.0 or 9.3.1 geodatabase not having this stored procedure.
By the way, I would like to strongly discourage you to tamper with any of the stored procedures or geodatabase system tables using SQL. Unless you are a true expert geodatabase administrator, there is a high chance of wrecking your geodatabase.
JakeSkinner
Esri Esteemed Contributor
Hi Brandon,
If you created your geodatabase with an SDE schema, the stored procedure will be owned by the SDE user.  Instead of dbo.next_rowid, try sde.next_rowid.
BrandonCales
You are correct. I was running this on my 9 box, but I checked my 10.1 test box and it's there.
