SQL Server Agent Job with Multi-Versioned View
1128
07-13-2010 07:17 AM
MeleKoneya
We have a stored procedure which updates a field in four featureclasses.     The stored procedure is as follows:
--UPDATE SYMBOLOGY FIELD
EXEC sde.set_current_version 'ums_app.MapGuide'
EXEC sde.edit_version  'ums_app.MapGuide', 1
Begin Try
Begin Transaction;
--wtr_hdyrant table
UPDATE ums.wtr_hydrant_mvw
SET symbology = owner + '/' + pm_state
WHERE owner + '/' + pm_state <> symbology
-- Commit Transaction;
--wtr_valve table
-- Begin Transaction;
UPDATE ums.wtr_valve_mvw
--wtr_main table
UPDATE ums.wtr_main_mvw
SET symbology = owner + '/' + main_type
WHERE owner + '/' + main_type <> symbology
--swr_main table
UPDATE ums.swr_main_mvw
Commit Transaction;
When I try to run the stored procedure as a SQL Server Agent Job,   it does not update the field in the feature classes.
If I run it 'manually' as a stored procedure it does work.      I am dbo.     Has anyone set up a SQL Server Agent Job to run a Stored Procedure?     If so,  do we need to 'run as' a particular user?    I had the owner set to my name, sde, and the data owner name.    Are there any other caveats to using this method?
Thanks for any suggestions,
Mele
MeleKoneya
One of DBAs was able to find a solution.
The "SQL Server Agent User" user was given the 'db_owner' role membership and it seems to have resolved our issue with the Stored Procedure.
