SQL Script runs successfully but changes not visible in Geodatabase Version
2392
13
09-27-2017 08:34 AM
AdelaideZumwalt1
SQL Script runs successfully but the changes are not visible in the geodatabase. The version gets created successfully but it seems like the version is either not saved or something else is going on...
EXEC dbo.create_version 'dbo.DEFAULT', 'WMMtoESRI', 2, 1, 'This version contains data pushed from WMM to ESRI';
EXEC dbo.set_current_version 'WMMtoESRI';
EXEC dbo.edit_version 'WMMtoESRI', 1;
BEGIN TRANSACTION
UPDATE ElectricNetwork.dbo.Regulators
SET esPhasing = WMM_Export.dbo.REGULATOR.wmPhasing
FROM WMM_Export.dbo.REGULATOR
WHERE
ElectricNetwork.dbo.Regulators.GUID=WMM_Export.dbo.REGULATOR.wmextVoltageRegulator__GUID_ESR
COMMIT;
EXEC dbo.edit_version 'WMMtoESRI', 2;
Thank you!
Asrujit_SenGupta
MVP Regular Contributor
Try the below and see if this works:
MERGE ElectricNetwork.dbo.Regulators_evw
USING WMM_Export.dbo.REGULATOR
ON ElectricNetwork.dbo.Regulators_evw.GUID = WMM_Export.dbo.REGULATOR.wmextVoltageRegulator__GUID_ESR
WHEN MATCHED THEN
UPDATE SET ElectricNetwork.dbo.Regulators_evw.esPhasing = WMM_Export.dbo.REGULATOR.wmPhasing;
Asrujit_SenGupta
You are updating the Feature Class\Table directly? Or the Versioned View for the feature class?
AdelaideZumwalt1
I was able to run the middle portion of the script and edit the geodatabase using SQL when it wasn't registered as versioned, now I wan't to do the same thing in a version.
Asrujit_SenGupta
You seem to be updating the Feature Class directly, which you should never do using SQL...
Check this link: Edit versioned data in SQL Server using SQL—Help | ArcGIS Desktop
The bold part should represent your Versioned View name, which is automatically created when you register as versioned a feature class. Check in Views in SQL Server Management Studio.
Also you won't need the below:
BEGIN TRANSACTION
COMMIT;
See the link provided for an example...
AdelaideZumwalt1
OK, I update the script with the versioned view name. Now I'm getting the error "UPDATE is not allowed because the statements updates view "ElectricNetwork.dbo.Regulators_evw" which participates in a join and has an INSTEAD OF UPDATE trigger.
Asrujit_SenGupta
Post the complete SQL you are using.. and I hope you changed the below as well
WHERE
AdelaideZumwalt1
UPDATE ElectricNetwork.dbo.Regulators_evw
WHERE
ElectricNetwork.dbo.Regulators_evw.GUID=WMM_Export.dbo.REGULATOR.wmextVoltageRegulator__GUID_ESR
Asrujit_SenGupta
The SQL looks good to me, but check the following links:
Update Versioned View with JOIN
arcgis 10.3 - Edit default version table view using SQL Server - Geographic Information Systems Stac...
Seems to be a known issue in MS SQL Server. So try using MERGE and check as suggested...
You will get multiple MS links for same issue, not even related to Esri, for this error...
Asrujit_SenGupta
WHEN MATCHED THEN
AdelaideZumwalt1
Thank you, I had that typed up just as you sent it. Unfortunately, while it creates a version and runs successfully, when I go the open the version the data is not there...
