SQL Query to find equal data
1151
12-18-2010 03:48 AM
RyanGarnett
Is there a way to find all the records is there are multiple records that have the same value?  I have a dataset where I am trying to find records that are different in one field, but share a common value in a different field.
FID     STATUS     VALUE
0        New          100
1        New          101
2        Old           101
3        Old           102
4        New          102
5        New          102
6        Old           103
I was thinking something like:
Where ([STATUS] = 'New' OR [STATUS] = 'Old') AND ([VALUE] IS "the same")
I would expect to have records 1,2,3,4,5 returned and not 0 and 6.  I am not sure what to write to run this type of query.
Thank you in advance.
DanaNolan
This sound like a COUNT problem. Within each group field, you want the singles.
Something like this, or a subquery (not sure if having is supported in ESRI, but subqueries sometimes are). If not, you can get a count using the Summary Statistics, and select from that table.
SELECT department, COUNT(*) as "Number of employees"
FROM employees
GROUP BY department
HAVING COUNT(*) = 1;
