Sprial encoding technique
1330
07-04-2013 05:24 AM
DenzilRockman
11222211
11222233
11222333
How would one compress the following data using a "spiral" encoding technique? Regards, Denzil
Louwde_Villiers
HI Denzil,
Have you had any success with this question of yours as I also need an answer to that exact same question. Please reply here if you have and I will reply again with my email address if we can possibly help one another.
Regards,
Louw de Villiers
JoeBorgione
Maybe you guys could explain what it is you are doing or want to do;  geocoding on this forum pertains to the translation of a descriptive location (specifically an address like 1234 Main St) to a pair of X,Y coordinates that the GIS can map.
A google search of Spiral Encoding was anything but address related...
DenzilRockman
I am currently doing a course on GIS, and this was 1 of the questions that we had to go and research.
B B E E E E
A A A E E E
D D B E E E
D D B B E E
D D D D D E
D D D D E E
(See above) If the compressed run length encoding is as follows 2,B,7,E,3,A,2,D,1,B,5,E,2,B,7,D,3,E,4,D
What would the spiral  encoding technique be below.
5 5 5 5 1 1 1 1
1 1 2 2 2 2 1 1
1 1 2 2 2 2 3 3
1 1 2 2 2 3 3 3
1 1 1 1 7 7 4 4
1 1 1 1 7 7 4 4
1 1 1 1 4 4 4 4
1 1 1 1 4 4 4 4
If I should write the spiral code would it be as follows 4,5, 4,1,4,3,3,2...
Regards,
Denzil
JoeBorgione
B B E E E E
A A A E E E
D D B E E E
D D B B E E
D D D D D E
D D D D E E
5 5 5 5 1 1 1 1
1 1 2 2 2 2 1 1
1 1 2 2 2 2 3 3
1 1 2 2 2 3 3 3
1 1 1 1 7 7 4 4
1 1 1 1 7 7 4 4
1 1 1 1 4 4 4 4
1 1 1 1 4 4 4 4
Regards,
Denzil
Tell you what Denzil-  I've only got 23 years in the field, and this is something I've never heard of.  Granted, I'm just a gray haired middle aged guy and perhaps this has slipped by me....
