Splitting unwanted parcels off layer.
1540
04-19-2012 09:56 AM
JoshuaJohnson
Hi everyone,
I am new to arc and am in the process of creating a map for our newly constructed bike path. I am using massgis data, and need to remove the unwanted parcels from my map. Is the best way to manually select each unwanted parcel? Or create a new layer from just the parcels I need?
Thanks in advance.
MarcinGasior
If you want to permanently remove those parcels, start Edit session (Editor Toolbar: Editor -> Start Editing), select parcel and delete.
You can also create a new layer without unwanted parcels:
- select those parcels, right click on layer: Selection -> Switch selection (now you have desired parcels)
- then right click on layer again: Data -> Export Data, make sure that Export type is 'Selected Features'
If you want to just remove parcels from display:
Use Identify tool and note IDs or unique numbers of unwanted parcels.
Then in Layer Properties -> Definition query tab: build an expression like:
[OBJECTID] NOT IN (1,2,3,5)
RyanForbes1
I personally prefer this method, even if I know I'll never need the rest of the data.  It is a good habit to get into when you begin working with larger, more permanent datasets.  It creates less clutter and requires less steps than creating a whole new feature of just the data you want to display.
