Split polyline
3424
03-19-2015 02:03 AM
Yaron_YosefCohen
Hello there,
I want to split randomly polyline into segments. but when i select the feature and start the editor the split option is blocked- why is it?
thanks for any help.
ArnoldKuilman
Did you select the right layer for editing when you started the editing process?
Example: If you select 'Layer 1' and you try to split a selected feature which consists in 'Layer 2' it won't work.
ArnoldKuilman
