Split line by attribute field
1603
09-11-2012 05:39 PM
ShaunLam
I currently have a single line that I want split at certain distances along it. The distances are all different and in a separate point shapefile. Any ideas ?
Thanks in advance.
Shaun.
ShaunLam
Thanks for your replies, Sorry if I was unclear, the point shapefile that I had were not the locations that I wanted the line split at.  To do what I needed to do I treated the line like a route, created a route then used the distance locations in the point file to split it by the locations I needed.
JonathanQuinn
Esri Notable Contributor
What version and license level are you using?  If you have ArcInfo, you can use Split Line at Points.
JohnSobetzer
Honored Contributor
If the points are at the locations you want to split the line and you have ArcInfo/Advanced you might look at the split line at point tool n Data Management Tools - Features.
There is an Arcscript to do this at http://arcscripts.esri.com/details.asp?dbid=14190
Another Arcscript that uses attributes is at http://arcscripts.esri.com/details.asp?dbid=14127 and there is a more recent version in the Net resources although I don't have the link for it right now.  To use this you might use a join to get the point attributes into the line layer.
Also see http://gis.stackexchange.com/questions/20402/how-to-divide-a-single-polyline-feature-into-multiple-f....  Also see the thread in this same forum: http://forums.arcgis.com/threads/51332-Dividing-Splitting-Lines
ShaunLam
