Digitised polygon becomes coarse when merged or clipped
1150
09-17-2012 02:24 AM
by Anonymous User
Not applicable
Original User: cuifeny
Hi!
I am using ArcGIS Editor 10.0 (service pack 3).
I find that when I digitise polygons and try to merge / clip them, the output polygon becomes coarse. Came across this problem before, and managed to "solve" the problem by copying the data into a new shapefile, repairing geometry, etc.
Example below. Top: Before merge, Bottom: After merge
[ATTACH=CONFIG]17714[/ATTACH]
[ATTACH=CONFIG]17715[/ATTACH]
Tried both file geodatabase and personal geodatabase - same result.
Would most appreciate advice for this.
Thanks in advance!
Cuifen
by Anonymous User
Not applicable
Original User: shlam
Have you tried using the dissolve tool ? I'm assuming you want to keep the same boundary but lose the internal polygon lines ?
