Just for the sake of it, I decided to do a little test. I densified the dataset I had by using the Densify tool to create a dataset with a vertex every 0.5 meter. I guessed this would get me close to Keith's dataset, but I still lag behind with an average 540 vertices per feature:
Results for densified layer
Polygons: 18968
Vertex count
Total: 10247488
Average: 540.25
Min: 4
Max: 18956
I will also copy the original dataset, which had the properties as listed in the previous post:
Original dataset
Polygons: 18968
Vertex count
Total: 535334
Average: 28.22
Min: 4
Max: 2106
Once the densification process itself was finished, I used ArcGIS 10.1 and the Copy Features tool to create a new Feature Class from the existing densified one, curious to know how much time that would take, and compare this with the writing of the data during the densification step, and the copying of the original dataset:
Copying of the original non-densified dataset:
18968 polygons densified in 18 sec, so 18968 / 18 = 1035.8 features written per second, and 535334 / 18 = 29741 vertices written per second.
Results for Densification step:
18968 polygons densified in 9 min 2 sec, so 18968 / 542 = 35.0 features written per second, and 10247488 / 542 = 18906 vertices written per second.
Results for Copy Features step of densified dataset:
18968 polygons copied in 1 min 54 sec, so 18968 / 114 = 166.4 features written per second, and 10247488 / 114 = 89890 vertices written per second.
The test configuration was:
Acer Veriton desktop:
- Core i5 2320 3.00GHz quad core processor
- 6 GB RAM (never used completely during the process)
- 1TB harddrive capable of up to 180 MB/s, connected on SATAII, but never or rarely exceeded read/write IO of over 10 MB/s during the process
- ArcGIS Desktop 10.1 SP1
- SQL Server Express 2012 SP1
- Dataset using SQL Server GEOMETRY storage
- No versioning on the datasets written!
"CONCLUSIONS" (take with a pinch of salt ;)):
This is definitely not server hardware, but it isn't a low spec laptop either, nor is it a shared server bogged down by other processes running on it... I am surprised to see how close the Densification step is to Keith's results:
- Keith had 7-9 "2100-vertex" polygons written per second, with 14700 to 18900 vertices per second.
- The Densification step is 35.0 "540-vertex" features written per second, and 18906 vertices per second
- The Copy Features step is 166.4 "540-vertex" features written per second, and 89890 vertices per second
- Original dataset copy is 1035.8 "28-vertex" features written per second, and 29741 vertices per second
- Vince achieved 113 "2100-vertex" pseudo random circles written per second, and +/- 240K vertices per second
Of course, the simple "Copy Features" step outperformed the Densification by a factor 4-5, but it still shows there is a real penalty in writing big polygons with many vertices, especially if additional computational or IO steps are involved, and it may actually be that Keith's hardware is simply running at its max when importing this data...
Vince's results on his laptop were even better than the Copy Features results on my desktop writing his pseudo random "2100-vertex" circles (in terms of vertices, not in terms of records / features), but that was using the se_toolkit. It may be that the overhead of ArcGIS is the problem here, and in addition my real world dataset contains a couple of extra non-system text fields with data in it, needing to be written too.
PS:
1) Writing to SDEBINARY using the Copy Features tool gave the following results:
18968 polygons copied in 1 min 18 sec, so 18968 / 78 = 243.2 features written per second, and 10247488 / 78 = +/- 131K vertices written per second.
2) I now also attempted writing to GEOMETRY using Copy Features, to copy to a Feature Dataset using another Coordinate System and even another Datum, thus forcing re-projection.
Results are:
18968 polygons copied in 3 min 51 sec, so 18968 / 231 = 82.1 features written per second, and 10247488 / 231 = 44361 vertices written per second.
As you can see, the re-projection slows the copying down by about 1/2 of the original speed compared to copying without re-projection (166.4 features / 89890 vertices per second). This again makes it likely the figures Keith supplied may actually not be that abnormal... although still on the low side of things.
