Spatial view of union of feature classes
2468
01-15-2011 09:01 PM
sheebaashraf
I want to create a spatial view that should contain the Union of all featureclass's. e,g
If we have a  4 feature classes each containing 10 features my view should contain 40 features
Pertinently I have to spatial and attribute query on this view.
VinceAngelo
Esri Esteemed Contributor
This may be possible, if you have the right combination of client, database, storage
method, topology, and indexing parameters, but it's not likely to be very efficient.
What is your environment like? How are your tables & layer defined? Are any of the
tables versioned? What would your ideal view look like?
- V
sheebaashraf
I'm using
1. Arcgis 10
2. Arcsde 10
3. Ms sql 2008
And at tha application side i'm using flex 2.0 apis
- V
VinceAngelo
You cannot create a spatial view (use 'sdetable -o create_view') to generate a UNION ALL query,
and you cannot UNION ALL layers with SDEBINARY storage, but you may be able to register such
a view on GEOMETRY or GEOGRAPHY storage with 'sdelayer -o register' or simply access it with
query layers, but only if the geometries share a single topology class and the id columns are
unique across the joined tables.
Generally speaking, if all the features share the same attributes, topology, and coordinate system,
they belong in the same table.  Views can then used to efficiently extract logical subsets.
- V
MichaelGinzburg
Hello,
Is this possible with 10.7?
How do I create such a view? Should I create a UNION ALL view with SQL and then register?
Thanks!
ModyBuchbinder
Hi Michael
Check this: Views in an enterprise geodatabase—Geodatabases in Oracle | ArcGIS Desktop
You can create it in SQL or with GP.
Have Fun
Mody
