Spatial View into Feature Dataset - SQL SERVER
2103
03-24-2011 10:17 AM
AlbertoAloe
Hi guys.
I need to update my old trick to logically store spatial views into feature datasets until ArcSDE 9.3.1.
Has anybody already done something like this for ArcSDE 10 ?
Old procedure as follows:
  • Create basic spatial view with ArcSDE command
  • Refine view with SQL
  • Create empty dataset with same spatial reference as the view
  • Register previously created spatial view with geodatabase
  • Enter dataset identifier into DatestID field into GDB_OBJECTCLASSES table for the record related to the spatial view
The only precaution was to use the feature dataset as a logical container staying away from versioning, topology and so on.
The new geodatabase system tables for 10 are different. I would do the same thing creating relationship "DatasetInFeatureDataset" linking spatial view to feature dataset. I have not tried yet. I'll do it after posting...
Any critic to this approach ?
Alberto
AlbertoAloe
OK.
It's even simpler than that. Last step of my old trick is not necessary (for 9.3.1 also). Just dragging and dropping in Arccatalog works fine.
It does not look like a trick any more.
So...steps as follows:
  • Create basic spatial view with ArcSDE command (at least objectid and shape fields)
  • If necessary refine view with SQL
  • Create empty dataset with same spatial reference as the spatial view
  • In Arccatalog drag and drop spatial view into destination feature dataset
Checking geodatabase system tables everything seems fine. In 10 relationship type is "DatasetInFeatureDataset" when the spatial view is inside the ds.
Alberto
