Spatial Indexes shows Tablespace Null ???
1585
05-13-2013 05:01 AM
User35489
Dear Admins,
I created a DBTUNE file with customized keyword, directing to below given example.
##CART_VECTOR_DEFAULT
GEOMETRY_STORAGE    "ST_GEOMETRY"
ST_GEOM_LOB_STORAGE  " STORE AS (
#                      TABLESPACE <lob segment tablespace_name>
                       ENABLE STORAGE IN ROW CHUNK 8K RETENTION CACHE) "
ATTRIBUTE_BINARY    "BLOB"
RASTER_STORAGE     "BLOB"
B_STORAGE           "PCTFREE 0 INITRANS 4" TABLESPACE SDE_TS
B_INDEX_ROWID       "PCTFREE 0 INITRANS 4 TABLESPACE  TS_NDX NOLOGGING"
B_INDEX_USER        "PCTFREE 0 INITRANS 4 TABLESPACE  TS_NDX NOLOGGING"
B_INDEX_XML         "PCTFREE 0 INITRANS 4 TABLESPACE  TS_NDX NOLOGGING"
B_INDEX_RASTER      "PCTFREE 0 INITRANS 4 TABLESPACE NOLOGGING"
B_INDEX_TO_DATE     "PCTFREE 0 INITRANS 4 TABLESPACE  TS_NDX NOLOGGING"
B_INDEX_SHAPE       "PCTFREE 0 INITRANS 4 TABLESPACE  TS_NDX NOLOGGING"
S_STORAGE           "PCTFREE 0 INITRANS 4" TABLESPACE TS_SNDX
S_INDEX_ALL         "PCTFREE 0 INITRANS 4 TABLESPACE  TS_SNDX NOLOGGING"
S_INDEX_SP_FID      "PCTFREE 0 INITRANS 4 TABLESPACE  TS_SNDX NOLOGGING"
F_STORAGE           "PCTFREE 0 INITRANS 4 TABLESPACE  SDE_TS
F_INDEX_FID         "PCTFREE 0 INITRANS 4 TABLESPACE   TS_NDX NOLOGGING"
F_INDEX_AREA        "PCTFREE 0 INITRANS 4 TABLESPACE   TS_NDX NOLOGGING"
F_INDEX_LEN         "PCTFREE 0 INITRANS 4 TABLESPACE   TS_NDX NOLOGGING"
A_STORAGE           "PCTFREE 0 INITRANS 4"
#                    TABLESPACE   <Default ADDS table tablespace name>
A_INDEX_ROWID       "PCTFREE 0 INITRANS 4
#                    TABLESPACE   <ADDS Table default index tablespace name>
                     NOLOGGING"
A_INDEX_SHAPE       "PCTFREE 0 INITRANS 4
                     NOLOGGING"
A_INDEX_STATEID     "PCTFREE 0 INITRANS 4
                     NOLOGGING"
A_INDEX_USER        "PCTFREE 0 INITRANS 4
                     NOLOGGING"
A_INDEX_XML         "PCTFREE 0 INITRANS 4
                     NOLOGGING"
A_INDEX_RASTER      "PCTFREE 0 INITRANS 4
                     NOLOGGING"
D_STORAGE           "PCTFREE 0 INITRANS 4"
#                    TABLESPACE <default DELETES Table tablespace name>
D_INDEX_STATE_ROWID "PCTFREE 0 INITRANS 4
#                    TABLESPACE <DELETES Table default index tablespace name>
                     NOLOGGING"
D_INDEX_DELETED_AT  "PCTFREE 0 INITRANS 4
                     NOLOGGING"
RAS_STORAGE         "PCTFREE 0 INITRANS 4"
#                    TABLESPACE <RAS Table tablespace name>
RAS_INDEX_ID        "PCTFREE 0 INITRANS 4
                     NOLOGGING"
BND_STORAGE         "PCTFREE 0 INITRANS 4"
#                    TABLESPACE <BND Table tablespace name>
BND_INDEX_COMPOSITE "PCTFREE 0 INITRANS 4
                     NOLOGGING"
BND_INDEX_ID        "PCTFREE 0 INITRANS 4
                     NOLOGGING"
AUX_STORAGE         "PCTFREE 0 INITRANS 4"
#                    TABLESPACE <AUX Table tablespace name>
AUX_INDEX_COMPOSITE "PCTFREE 0 INITRANS 4
                     NOLOGGING"
BLK_STORAGE         "PCTFREE 0 INITRANS 4
#                    TABLESPACE <BLK Table tablespace name>
                     LOB(BLOCK_DATA) STORE AS (
BLK_INDEX_COMPOSITE "PCTFREE 0 INITRANS 4
                     NOLOGGING"
UI_TEXT             "User Interface text for DEFAULTS"
XML_DOC_UNCOMPRESSED_TYPE   "CLOB"
XML_IDX_TEXT_UPDATE_METHOD "NONE"
XML_DOC_MODE               "COMPRESSED"
XML_DOC_LOB_STORAGE        "NOCACHE NOLOGGING CHUNK 4K PCTVERSION 5 DISABLE STORAGE IN ROW" TABLESPACE SDE_XML
XML_DOC_VAL_LOB_STORAGE    "NOCACHE NOLOGGING CHUNK 4K PCTVERSION 5 DISABLE STORAGE IN ROW" TABLESPACE SDE_XML
XML_DOC_STORAGE     "PCTFREE 0 INITRANS 4" TABLESPACE SDE_XML
XML_DOC_INDEX       "PCTFREE 0 INITRANS 4 TABLESPACE SDE_XML NOLOGGING"
XML_IDX_STORAGE     "PCTFREE 0 INITRANS 4" TABLESPACE SDE_XML
XML_IDX_TEXT_TAG_STORAGE   ""
XML_IDX_INDEX_PK    "PCTFREE 0 INITRANS 4 TABLESPACE XML_NDX NOLOGGING"
XML_IDX_INDEX_ID    "PCTFREE 0 INITRANS 4 TABLESPACE XML_NDX NOLOGGING"
XML_IDX_INDEX_TEXT  ""
XML_IDX_TEXT_UPDATE_MEMORY ""
XML_IDX_INDEX_TAG   "PCTFREE 0 INITRANS 4 TABLESPACE XML_NDX NOLOGGING"
XML_IDX_INDEX_DOUBLE "PCTFREE 0 INITRANS 4 TABLESPACE XML_NDX NOLOGGING"
XML_IDX_INDEX_STRING "PCTFREE 0 INITRANS 4 TABLESPACE XML_NDX NOLOGGING"
XML_COLUMN_STORAGE    "SDE_XML"
# Example for setting XML_COLUMN_STORAGE to native XML type.
#XML_COLUMN_STORAGE    "DB_XML"
#XMLDB_INDEX_TAG       "YES"
#XMLDB_INDEX_FULLTEXT  "NO"
END
But for my surprise i view the information about the Spatial Index for a layer is created in TableSpace = Null
What could be the reason ?
Please input your valuable comments
My Environment: RHEL 6, Oracle 11.2.0.3.0, ArcSDE 10.1 SP1
With best regards
Thanks
Abdullah
ForrestJones
Hi Abdullah,
Is the correct value in the sde.dbtune table? The tablespace info might not be there. The end quote might be in the wrong place:
should maybe be:
S_STORAGE "PCTFREE 0 INITRANS 4 TABLESPACE TS_SNDX"
ForrestJones
Hi Abdullah,
should maybe be:
User35489
Hi FOJO,
Thanks for your input,
I tried making changes you highlighted. Still the index created goes in "So called 'Null' as viewed by SQL Developer" Tablespace
Any more ideas ? Dudes . .
-AS
VinceAngelo
Esri Esteemed Contributor
Did you just change it in the file, or did you change it in the file then use
'sdedbtune' to update it in the SDE.DBTUNE table?
Please mark FJ's answer as the solution.
- V
User35489
- V
Hi Angelo,
I exported dbtune, made changes and imported it back..
I think the issue is with SQL Developer, when i view the details for tables, it shows null in Tablespace. But just now when i viewd properties by selecting EDIT it showed me the correct tablespace.
Any ways the answer given be FOJO helped me to correct the mistake of quote placement.
Thanks FOJO, Vince
Regards
VinceAngelo
Welcome to the wonderful world of ACID.  You need to refresh open cursors
to see changed database contents.
- V
