SOLVED: Problems Reclassifying Rasters
13611
05-20-2011 08:42 AM
EricaNewton
I've been working on a solution to this problem for a while now so thought I'd post the workaround that I found.
I am importing landsat bands and attempting to reclassify the DN Values 0-255 into two new classes, for example 0 and 1.  For most bands, using the reclassify function works.  However, for some band files, reclassifying either does not work and I get an error message,
The input raster minimum/maximum (huge number) is out of range.  To ensure a correct reclassification, edit ranges or use a different precision settings in the reclassification dialog box.
Sometimes the reclassify tool works, but my output is incorrect - an image showing vertical lines or bands with values 0 and no data.
I tried to calculate statistics first because I noticed that this file, unlike the other files I worked with, did not have statistics calculated, but when I tried that I get the error message,
Invalid drop item:  One or more dropped items were invalid and will not be added to the control.
My solution:
Build an attribute table for the raster data set.
Build Statistics by clicking the symbology tab "discrete color".
Reclassify the raster by using the tool "reclass by table".  I built the table in the reclassify tool - it's easy there to create and save a table based on your preferences for the reclass function.
This successfully built a correctly reclassed image for me.
Hope this helps someone struggling with the same problems!
ThomasDilts
Erica,
This is great.  I'm just curious if you have any thoughts on how one might go about reclassifying a mosaic dataset.  I'm concerned that I may have hit a dead end.  The mosaic dataset really seems to be geared toward displaying imagery and less toward analyzing imagery.
EricaNewton
I'm sorry Tom, I have no experience with mosaic datasets...
Erica
