Annotation
768
05-30-2011 06:50 AM
WalterBeach
I'm hoping it is ok for me to ask stupid questions.   I'm fairly new to GIS using arcEditor.
I am wondering if it is possible to lock the size of annotation at a certain zoom level without creating an annotation layer.
Example: I have a map with feature points and in the attribute data is Address information.   I want to take the Address number and label the feature, but when I zoom in and out of the map the text increases and decreases in size as well as moves within the feature.   I adjusted the text to stay on top of the feature to prevent it from moving, but then I loose the ability to adjust the direction.
Example some text is too large to fit horrizontally, so some text I want to display horrizontal and some vertically.
I know that I could create an annotation layer and add it to the map, but it would mean recreating all the annotation and placing it properly on the map, as well as when a property changes I would have to adjust the annotation and the attribute table.
Any suggestions would be appreciated.
Thank you,
Walter
JonWebb
Have you tried setting a reference scale?
Get the map looking the way you want it. Right click on Layers, then Set Reference Scale.
