Snapping: Can't select one layer
1419
03-07-2012 02:21 AM
KatharinaDubach
I've got a map with several shapefiles. Now I'm editing one, let's call it MyPolygons, and I want to set it to snap to the vertices of MyPolygons. But the Snapping Options dialog won't list MyPolygons. What's wrong here??
The weird thing is: I've got another layer in my TOC called Boundaries that also points to MyPolygons as its data source. I can snap to Boundaries.
Copying MyPolygons to a new mxd won't help the situation.
MyPolygons was symbolized using a .lyr-file whose source I had to adjust to make it work again. Could that be part of the problem?
I'm on ArcView 9.3 an Windows XP.
SisiYan
You can try exporting the shapefile out to a feature class in a geodatabase and see if the new feature class can be snapped at all.
KatharinaDubach
If I add the shapefile directly to ArcMap (no symbology applied), I can snap to it. But not if I use the .lyr file. Must be something wrong with that, then...
